My D-I-Y Painting Turntable For $11.16
Postby jimmac » Tue Oct 18, 2011 2:45 pm
Visited my local Bunnings store this morning (Tue, 18th) simply to browse and get some "me time". Whilst there, I purchased three good-sized MDF offcuts and two pairs of small PLATE castors.
Cost:
3 x 18mm MDF = $5
2 x Plate Castors = $6.16
I cut the smallest piece of MDF in half and, with a compass, drew a circle leaving plenty of space to the edges. I then positioned and screwed the plate castors. Next, I measured from the centre mark of the compass pin to the outside of one castor turned to its broadest point and again using the compass set to that measurement marked a circle on the second piece of MDF. Then some "liquid nails" to stick fly-screen spline just outside the pencilled line and I had my D-I-Y turntable. The "liquid nails" should (Murphy's Law notwithstanding :lol: ) retain the top plate in place should the castors rotate excessively.
$11.16 + 1 hour + materials previously on-hand = a good morning's work.
Jim
32.06'77.27'S 115.80'84.78W
“What language is that you are speaking now? It sounds like balls". - Victor Meldrew
jimmac
Re: My D-I-Y Painting Turntable For $11.16
Postby wally » Tue Oct 18, 2011 2:49 pm
jim a picture is worth a 1000 words..could you post please..have been spraying this morning..I need something like this
wally
Postby jimmac » Tue Oct 18, 2011 5:10 pm
Will do Wally, probably tomorrow. Need to purchase new batteries for my digi camera.
Jim
jimmac
Postby wally » Tue Oct 18, 2011 5:21 pm
that be great..you can get some more "me time" while your at it! lol
wally
Postby jimmac » Tue Oct 18, 2011 7:03 pm
Wally
"Liquid Nails" has reacted negatively with flyscreen spline. Plan B will be initiated tomorrow morning and will post when complete.
It's fairly straightforward.
Regards.
Jim
jimmac
Postby jimmac » Wed Oct 19, 2011 1:13 pm
"Plan B" Wally.
MDF - 52cm X 36cm X 18mm
Cutting
Base underside showing small rebate for bent coathanger wire araldited in place.
Base portion of turntable. Wire acts as central pivot for upper half and is NOT load bearing.
Underside of turntable depicting partial-depth hole for central pivot.
Finished article.
All that is required to complete my turntable is to manufacture a "skirt" from a cereal box to minimize overspray on the castors, etc.
Jim
jimmac
Postby wally » Wed Oct 19, 2011 1:28 pm
now I get it! clever
thanks for your time and effort to post
cheers
wal
wally
Postby Damo » Sat Nov 12, 2011 9:42 am
I got a couple of these at IKEA....can't remember how much they were, but not horribly expensive..
Turntable 3.JPG (118.9 KiB) Viewed 7783 times
Turntable 2.JPG (87.81 KiB) Viewed 7783 times
Turntable 1.JPG (73.31 KiB) Viewed 7783 times
Damo
Postby jimmac » Sat Nov 12, 2011 3:52 pm
Well done Damo
Provided they are inexpensive and work, what the heck hm? My spray booth is a large cardboard box (lined with black plastic) which held our coffee machine at delivery - works for me!! :)
Jim
jimmac
Postby Zaggy » Thu Aug 29, 2013 11:52 pm
My solution is no where near as neat or evolved!
Spray Booth - Large cardbard box, with extra cardboard Gaffa'd on to make a little shelf in front and a piece of cloth I can drop down the opening if need be!
Painting Turn Table - a piece of Melamine/Chipboard Shelf, with a few blocks of 3inch thick High Density Foam to position things on. Moved very manually! ;)
Dan
